Hi, just wanted to share my experience with swapping the fan. Guys from Beelink have sent it to me pretty rapidly. The swap was I’d say a bit challenging for the person that cant build a pc easily. You need to be careful, follow the instruction video. And you need to figure some stuff out yourself, that is not in a video. But I’ve managed to swap the fan successfully.
Was it worth it - definitely yes. It gave me -6dB from the original fan. You could hear only the noise of the air coming out of the vents. You can work with this computer near by with the swapped fan.
But I didn’t stop there and installed coolercontrol app on linux. And created the profile for cpu temp, gpu temp and ssd temp. Now it is literally silent. And I’m happy :)
Definitely recommend the swap.
