fromthebark
Please provide a photo of the SN code located on the bottom of your machine and a screenshot of your machine’s BIOS main page. We will review them.
You may also try the following methods:
②Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :[https://url.bee-link.cn/UX3B].
