I have a Beelink GT King which, after years of use, I would like to update.
Problem is the sticker on the bottom of the device is so faded that I cannot make out the serial number, is there anywhere else I can find it? And, if I manage to decipher any part of the number is that at all useful in determining which upgrade can be used? Finally, how much damage will be done if I make a guess at this and flash the wrong upgrade? I love this box and will use it as is rather than risk wrecking it.
Thank you in advance, with regards,
