Steved I’m looking to upgrade the slot #2 on the EQ14 to 4TB. Can someone confirm this is possible (I have seen 2TB and 4TB max both stated) Also, can someone recommend a good option for the drive? Speed isn’t a major factor.
Beelink CS-Bony Steved Thank you for your letter. EQ14 has two slots, each supporting a maximum of 2TB. It supports M.2 SSD PCIe(2280). System disk:M.2 PCIe 3.0 ×4(NVMe/SATA3) Storage disk:M.2 PCIe 3.0 ×1(NVMe)
genehilton Beelink CS-Bony Is this correct? I’m thinking about buying an EQ14 and it says right on the product web page specs: Dual M.2 2280 PCle3.0 SSD Slots Max 8TB Ships with a SATA III SSD Options: 500GB That would imply that 4TB would work. Please clarify.
Beelink CS-Bony genehilton Sorry for causing you trouble. Here are the latest specifications. EQ14 has two slots, each supporting a maximum of 4TB.
