Hi thank you for that reply and yes i am aware of that per the instructions. I did get the initial problem sorted out and it was working for a while, but today, when I booted my computer up, neither drives appeared. After trying diffferent USB ports on my Mac Studio, they eventually showed up again. Then I plugged the cable back into the original port (on the back) and they showed up there after having not shown up when plugged in there moments earlier. I believe this may be a USB voltage regulation issue. Do you have any suggestions on how to resolve this so that the Studio Mate always gets the voltage it needs? For the record, I have a 40W power adapter attached with an OWC USB-C cable (that came with a Thunderbot 4 OWC Pro Dock).
