Don’t worry, the PC has one-year warranty. Please send us a picture of SN on the bottom of the PC.
Here are some potential solutions: First, Please turn off the PC , unplug the power supply, and press the CMOS button (if no CMOS button, please put the pin in the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms or [https://url.bee-link.cn/5FdW]. If the problem persists, please try other solutions:
②Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial [https://url.bee-link.cn/AzzB] or https://mega.nz/file/7nwDmCaL#UyzSmVkqJG8HW9dhjHhLkkzdP9gt2Br3xyCG1SCdbrA
After you’ve tried these steps, please share the results with us. If the issue still isn’t resolved, we’ll further discuss the next steps.
We appreciate your patience as we work to fix this for you.
