win11 Sorry for inconvenience to you.Please send us a picture of the serial number and BIOS version.
What was your machine’s temperature before updating the BIOS?Please try using a different software to detect the machine temperature.
Your machine crashes under load, please try the following measures:
Please change to a different power supply.
Overheating. If your PC is overheating, please check if the fan is spinning. You can also turn off the turbo boost. Go to Control Panel — Power Options — Change to High Performance — Change Plan Settings — Advanced Settings — Processor Power Management — Change both 100% and 99%, click Save.
Update the graphics driver: Please uninstall the graphics driver in the Device Manager and install the new one. Here is the driver source: https://url.bee-link.cn/UX3B Tutorial: https://url.bee-link.cn/wEmk
