LordGG
Don’t worry, the PC has one-year warranty. Please send us a picture of SN on the bottom of the PC and a picture of the purchase record. Here are some potential solutions:
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :https://url.bee-link.cn/UX3B Tutorial:https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
If can’t solve it, it is recommended that you reinstall the system on Microsoft ’s official website and remember to back up your data first. Here is the tutorial: https://url.bee-link.cn/74zu
