soon The SER5 PRO 5800H can be used to build a Proxmox Home Lab.
It supports AMD-V virtualization technology, and its performance and scalability are sufficient to support the Proxmox virtualization platform, as well as the operation of the Jellyfin media server and the Home Assistant smart home hub.
Install the Proxmox VE system
Deploy Home Assistant in Proxmox
Deploy Jellyfin in Proxmox: Create an LXC container and install Jellyfin
Optimization and debugging: Add a 2.5-inch HDD to increase storage, enable AMD integrated graphics acceleration in Jellyfin to improve video transcoding efficiency.
