Hi All,
I use a U59 PRO with Proxmox 9.0.xx.
All is working fine with Linux kernel 6.8.
Since I upgraded to Linux kernel 6.14 and now 6.17 the U59 freezes after a few minutes.
Nothing on the screen like a crash debug ; only a freeze.
When I reboot on kernel 6.8 all is then working fine again.
I asked Bee-Link and they sent my a Bios update (20230217).
After patching the Bios the problem is still the same : freeze with kernel 6.17.
Has someone notice the same issue ? If yes, have you find a solution ?
Many thanks for help
Best Regards
Lalsacien
