On the Beelink GTR9 Pro is it possible to enable the AMD SmartAccess Memory feature? It shows unsupported in the AMD Adrenalin software in Windows 11. I have Above 4G Decoding and Re-Size BAR Support enabled in the BIOS but it seems that isn’t working. I also read that the Compatibility Support Module (CSM) need to be enabled but I can’t find that BIOS setting so I am not sure what to do for that.
Is there sometime else I need to do in order to enable the AMD SmartAccess Memory feature?
