AlexanderKl
Sorry for the trouble. Here are some potential solutions:
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :https://url.bee-link.cn/UX3B tutorial:https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
