I am getting the error "DirectX 12 is not supported on your system. Try running without the -dx12 or -d2d12 command line argument’.
I purchased a BeeLink GTi13 Mini PC.
When I run DxDiag it shows I AM running Dx12.
System Information
Time of this report: 11/28/2025, 14:11:30
Machine name: DESKTOP-K3CJQ1L
Machine Id: {E6F7AA92-C3E2-4803-8EDD-C9196CA8F63D}
Operating System: Windows 11 Pro 64-bit (10.0, Build 26200) (26100.ge_release.240331-1435)
Language: English (Regional Setting: English)
System Manufacturer: AZW
System Model: GTi
BIOS: GTi12T201 (type: UEFI)
Processor: 13th Gen Intel® Core™ i9-13900HK (20 CPUs), 2.6GHz
Memory: 98304MB RAM
Available OS Memory: 98064MB RAM
Page File: 11062MB used, 93144MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.7.7
Auto Super Res Version: Unknown
System Mux Support: Mux Support Inactive - Ok
Mux Target GPU: dGPU
Mux Incompatible List:
DxDiag Version: 10.00.26100.7019 64bit Unicode
Display Devices
Card name: Intel® Iris® Xe Graphics
Manufacturer: Intel Corporation
Chip type: Intel® Iris® Xe Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_A7A0&SUBSYS_22128086&REV_04
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 49159 MB
Dedicated Memory: 128 MB
Shared Memory: 49031 MB
Current Mode: 1920 × 1080 (32 bit) (75Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.647461,0.340820), Green(0.318359,0.618164), Blue(0.152344,0.058594), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Acer SA230
Monitor Model: SA230
Monitor Id: ACR057E
Native Mode: 1920 × 1080(p) (74.973Hz)
Output Type: HDMI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: AdvancedColorSupported
Using DDisplay: Yes
WCG: Wcg Supported
Active Color Mode: DISPLAYCONFIG_ADVANCED_COLOR_MODE_SDR
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3a06f99bddd1c022\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3a06f99bddd1c022\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3a06f99bddd1c022\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_3a06f99bddd1c022\igd12umd64.dll
Driver File Version: 32.00.0101.7080 (English)
Driver Version: 32.0.101.7080
DDI Version: 12
Adapter Attributes: HARDWARE_TYPE_GPU,D3D11_GRAPHICS,D3D12_GRAPHICS,D3D12_CORE_COMPUTE,D3D12_GENERIC_ML,D3D12_GENERIC_MEDIA
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1,1_0_CORE
Driver Model: WDDM 3.2
Hardware Scheduling: DriverSupportState:AlwaysOff Enabled:False
Displayable: Supported
Graphics Preemption: Triangle
Compute Preemption: Thread group
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Integrated
GPU Mux Support: Experimental, None - Unknown Error
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:True Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 11/2/2025 6:00:00 PM, 2761056 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-E4E0-11CF-9EF8-7702ABC2ED35}
Vendor ID: 0×8086
Device ID: 0xA7A0
SubSys ID: 0×22128086
Revision ID: 0×0004
Driver Strong Name: oem0.inf:5f63e534e0135c88:iRPLPD_w11_DS:32.0.101.7080:PCI\VEN_8086&DEV_A7A0
Any help would be appreciated.
