leonardify
Don’t worry, the PC has one-year warranty.Here are some potential solutions:
②Your BIOS is already up to date and does not need to be updated.
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source : https://url.bee-link.cn/mGVP tutorial:https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
