Hi,there
- Please uninstall the wifi driver and then resatart the PC to see if it works.
- Please right click the windows —setting -troubleshooting —other toubleshooters— internet—run , let the PC diagnose the problem and solve it automatically.
3.. Go to device manager , click the property of the Intel WiFi driver —advanced–choose property 802 ax, value also choose 802 ax.
4.CLR CMOS
Secondly, Please hit the “CLR CMOS” button for about 10 seconds.
Ten minutes later, plug the power supply and HDMI cable, turn on the PC again,
5.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
6.Go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
7.Here` s a software for you to fix the WIFI issue, see if it works.
Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg
8.Disable Fast Startup
In Control Panel, click the Power Options. Select the Choose what the power buttons do. Uncheck the “Turn on fast startup.”, click save changes.
