Grey Okay, we await your update.When clearing the CMOS, please unplug the power supply and other external devices. Wait ten minutes before turning on the computer.
Could you please send us a picture or video of the blurry PC screen? This would help us better assist you.
You can try the following measures
1.Check the display resolution: Ensure that your PC is set to the recommended resolution for your display. To do this, right-click on your desktop, select “Display settings,” and adjust the resolution to the recommended setting.
2.Adjust display settings: You can try adjusting the settings on your display to improve clarity. Use the buttons on the display itself to access its menu and adjust parameters such as brightness, contrast, sharpness, and any other image-enhancing options.
3.Adjust ClearType settings (Windows): If you’re using Windows, you can try adjusting ClearType settings. Type “ClearType” in the Windows search bar, open “Adjust ClearType text,” and follow the on-screen instructions to optimize text clarity.
