williw Placed an order for a GTi15 Ultra AI PC 285H(96GB+2TB) & EX Pro Docking Station Plan on using a Nvidia RTX Pro 5000 BW in the EX Pro Dock, reason beeing the card uses “only” 300W, but has 48 GB VRAM Any reason this combination should not work?
Beelink CS-Yvette williw Thank you for your message. You can use the Nvidia RTX Pro 5000 BW graphics card, which is compatible.
williw Thank you for answering my question. Would like to be ready when I get the EX Pro Docking Station. My RTX Pro 5000 uses a 12V-2×6 Power Connector. What kind of Adater/Cable do I need for connecting to the Dock and any idea where to get it?
Beelink CS-Yvette williw You can use the cable supplied with our docking station. One section can be split into a 6+2-pin configuration.
williw Got my system, thank you Beelink! I have a WD Black SN850X 8000GB with Heatsink Dimensions: l 80 mm, w 220 mm, h 90 mm It does not fit in the GTi15 Ultra - to high, getting to hot Wil it fit in the Mate mini 80Gbps Dock? Thx again for your help
williw Got my system, thank you Beelink! I have a WD Black SN850X 8000GB with Heatsink Dimensions: l 80 mm, w 22 mm, h 9 mm It does not fit in the GTi15 Ultra - to high, getting to hot Wil it fit in the Mate mini 80Gbps Dock? Thx again for your help
Beelink CS-Yvette williw Thank you for following up. The MATE SE does not support SSDs with heat sinks.
