tanman81
Please send us a picture of SN on the bottom of the PC .
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :[https://dr.bee-link.cn/index.php?dir=] , click the item model , then you can find the related driver.
The tutorial: https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Have a nice day~
