huato
①There might be something wrong with the hard ware components,maybe it is loose.
Please take out the SSD and RAM and then put them back , make sure they are installed properly.Also please clean the contacts of the RAM with a rubber. Here is the tutorial https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc or https://url.bee-link.cn/AzzB
If it still doesn’t work, please press delete key as soon as you turn on the PC, so that you can go to BIOS, please check you can see SSD there.
② Use the ‘Windows + R‘ keyboard shortcut to launch the Run tool. Here, type ‘CMD‘ and then click on OK. Copy-paste the below commands one by one, and press Enter. You have to do this for each of the three commands. You can read about the DISM command here and what exactly it does. By the way, you need an active internet connection for the DSM command to work.
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
Now, copy and paste the below command in the CMD window. Press Enter when done. Your system will run the System File Checker utility, which will take some time to verify the integrity of your OS. When the entire process is done, your system should now be stable and no longer encounter the IRQL_NOT_LESS_OR_EQUAL BSOD error.
SFC /scannow
③ Reset your PC. Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
Then start the Reset
④ Please try to re-install the system. You can visit the Microsoft official website to reinstall the operating system.
