Hi!
SER9 Pro (HX 370) 64GB/2TB
Bios: T407
My SER9 Pro froze and restarted while playing Battlefield 6 (about an hour).
I see this messages in Windows journal:
The system rebooted after encountering errors. Possible causes of the error: the system stopped responding to requests, a critical failure occurred, or the power supply was unexpectedly disconnected.
The ACPI thermal zone _TZ.TZ01 has been enumerated.
_PSV = 0 K
_TC1 = 1
_TC2 = 2
_TSP = 2000 ms
_AC0 = 0K
_AC1 = 0 K
_AC2 = 0 K
_AC3 = 0 K
_AC4 = 0 K
_AC5 = 0 K
_AC6 = 0 K
_AC7 = 0 K
_AC8 = 0 K
_AC9 = 0 K
_CRT = 383 K
_HOT = 0 K
Minimum control = 0
_CR3 = 0 K
I didn’t test BF6 for very long on previous BIOS versions. The gaming sessions were shorter. But I ran the Superposition test about 20 times in a row on Extreme and Normal settings and didn’t encounter any such problems, for example.
And another reboot occurred during BF6 gameplay, just 10 minutes in:
"“from windows journal”"
_PSV = 0 K
_TC1 = 1
_TC2 = 2
_TSP = 2000 ms
_AC0 = 0K
_AC1 = 0 K
_AC2 = 0 K
_AC3 = 0 K
_AC4 = 0 K
_AC5 = 0 K
_AC6 = 0 K
_AC7 = 0 K
_AC8 = 0 K
_AC9 = 0 K
_CRT = 383 K
_HOT = 0 K
Minimum control = 0
_CR3 = 0 K
I am attaching a recording from the sensors made in HWiNFO64 right up to the moment of the reboot. The log can be conveniently viewed using GenericLogViewer for HWiNFO. For me temps looks fine. looks like BIOS/ACPI related issue for me.
I found similar issue on reddit -
I changed this setting and the problem has not reappeared yet. I will write here if the problem recurs.
I hope Beelink support will pay attention to this.
