Hi,
I have a SER6 and I am having problems with sound on my headphones that are using 3.5mm jack. Sound on the monitor is fine, but on the headphones it is both extremely quiet and heavily distorted which makes it unusable. The headphones are not the problem as they work perfectly fine on another PC.
What could be the issue?
SN: C69004JG80213
SER6-P-E-00EJ0W64PRO-DP/XA
