rzr
1.Please clear the CMOS. Please turn off the PC , unplug the power supply, and put the pin in the pinhole and press it for about 10 seconds , restart the PC after ten minutes. Here is the tutorial [https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms]
- Please uninstall the wifi driver and then resatart the PC to see if it works.
3、Overheating. If your PC is overheating, please check if the fan spins. You can also turn off the turbo boost. Adjust power settings: Adjust the power settings on your PC to optimize performance and reduce heat generation. Lowering the maximum processor state or using power-saving modes can help.Go to control panel —power option—change to High performance— change plan setting—advanced setting —processor power management— change both 100% to 99% , click save.
- Please right click the windows —setting -troubleshooting —other toubleshooters— internet—run , let the PC diagnose the problem and solve it automatically.
5.Please update the driver.
Here is the driver file: https://url.bee-link.cn/wPts
The tutorial: https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Go to device manager , click the property of the Intel WiFi driver —advanced–choose property 802 ax, value also choose 802 ax.
Please make sure your WIFI signal is full.
8.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
9.Please go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
10.Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg or https://url.bee-link.cn/meE5
Right click windows –go to settings—network & internet—-Advanced network settings–network reset–reset now
Please go to device manager, uninstall the WIFI driver, then reinstall the PC.
Have a nice day~
