perspicacia This is my GT-King-Pro SN:6B9HH1MF60144 It says the build is 924PO_wol_bt Is this the best version or is there something more up to date for my model and if so what are the benefits/upgrades? Thanks
Beelink CS-Yvette perspicacia This is the 927 firmware version: url.bee-link.cn/Y9yO Tool: url.bee-link.cn/w367 Tutorial: url.bee-link.cn/cIcR The latest firmware update includes an aging APK.
perspicacia Thanks Will this install using Local Update? Also does installing this firmware wipe my apps/data?
Beelink CS-Yvette perspicacia Firmware updates are installed via local updates. This will clear applications/data.
Beelink CS-Yvette perspicacia You can try unchecking the “Erase Data” option, which should preserve your data.
