Beelink CS-Yvette
When the SSD disconnects, check if the device or adapter cable was touched, which may cause poor contact.
Everything is fine - use also new cable
Please verify if the Mate Studio device is still listed under Thunderbolt/USB4 Devices in Device Manager when the SSD disconnects.
Yes listed
Disconnect the external power supply.
No changes
Format the SSD and change its file system.
No changes
Confirm if there are any other Thunderbolt/display devices connected to other Thunderbolt ports on the customer’s computer. If yes, disconnect them and test.
Only display - disconnected - no changes
Please replace the thunderbolt cable.
Replaced
Disable Low Power Mode in Settings.
Done
Disable the function of turning off peripherals during hibernation.
Done
Please update the your Mac Studio system version to the latest one.
Latest OSX
