Diorisis Hi can I have the latest firmware update for my GT1 please S/N: A912BSAF70202 16G Thank you. Best regards.
[deleted] Diorisis Link:https://mega.nz/file/nqBgUTpb#Rc_ST-2eCFpREtVbg-EJxWuRxNgtGdlJW-_Y4nZMn5k , Turoial https://url.bee-link.cn/zjmo Tool:url.bee-link.cn/w367
Dotter Hello! Could you please tell me if this firmware is suitable for my BeeLink GT1 model (6.0.1 16GB, SN A912BKLG00011 16GB, GT-T_V20_20160810)? I have attached a photo.
Beelink CS-Sylvia Dotter Here is the firmware:https://url.bee-link.cn/aoDk Turoial https://url.bee-link.cn/zjmo Tool:url.bee-link.cn/w367
Nuevoporaqui Hola necesitaría ayuda para encontrar firmware para TVbox gt1 ultimate. Número de referencia: s/n LPN11GQEG80413 32G Referencia en placa base: GT-LP ver1.1 Gracias de antemano Saludos
Beelink CS-Sylvia Nuevoporaqui Aquí tienes el firmware: https://url.bee-link.cn/rHpZ Tutorial: https://url.bee-link.cn/zjmo Herramienta: url.bee-link.cn/w367
Beelink CS-Sylvia Nuevoporaqui Esperamos que el firmware resuelva el problema de su TV‑box que se queda atascado en el logo de arranque. Recuerde seguir cuidadosamente el tutorial antes de flashear el dispositivo. Si encuentra cualquier error durante el proceso de actualización, no dude en contactarnos.
Beelink CS-Sylvia Dotter We’ve gotten lots of requests for firmware for our 7-8 year old TV Boxes recently. The original firmware is old and most new apps cannot run.Could you share what you are using these old TV boxes for? Local media, streaming, home lab or other purposes? Thanks!
STILOVR Hi everyone, I have this GT1; I don’t have the serial number, but I’m attaching a photo to see if it helps. I’d like to know if there is an Android update available. Regards,
Beelink CS-Sylvia STILOVR Here is the firmware:https://url.bee-link.cn/qjoB Tutorial https://url.bee-link.cn/zjmo Tool:url.bee-link.cn/w367
STILOVR Beelink CS-Sylvia Hi. Is it normal that I can’t connect to any PC via USB? I also tried using an SD card, but after restarting, it just stays stuck on the logo—is that normal, or is it not doing anything? Thanks a lot for your time and help.
Beelink CS-Sylvia STILOVR There is a flashing button on the back of the motherboard; press this button and then connect the USB port to your computer—please ensure you use the USB 2.0 port. If the computer still fails to detect the device, please take a clear photo of the back of the motherboard.
