Open your terminal and edit the GRUB configuration file:
sudo nano /etc/default/grub
Locate the line starting with GRUB_CMDLINE_LINUX_DEFAULT and append amdgpu.gpu_recovery=1 amdgpu.dcdebugmask=0×10 inside the quotes. Save the file (Ctrl+O, Enter, Ctrl+X), run sudo update-grub, and reboot your computer.
