- #1
Purchased a Beelink SER8 miniPC (AMD 8845HS) a few weeks ago. I’ve been attempting to find reference to the NPU (aka AMD XDNA) in both Windows 11 “Device Manager” and “Task Manager” with no luck. Also search the BIOS extensively and find no reference. My question is - was there a BIOS upgrade that had the NPU enabled? Or has Windows 11 version 23H2 not made that visible yet?
