PanAmMan I need to replace a work computer that is outdated but has some things that need to be on a new computer. I was wondering if I can clone my old HDD and install into the s12 instead of using the HDD and operating system that it came with ?
PanAmMan support1 Yes im going to use a 2.5 ssd. Do i need to pull the m.2 out of it since i wont be needing it ?
support1 PanAmMan Hi there, If you don’t need it, you can take it out. Or you can use it as a storage .
