Will the USB C port on a AMD Ryzen 7 5800H support dual monitors through either a splitter or daisy chain setup? USB C with DP alt mode does have this capability but it appears compatibility is hit and miss depending on hardware.
If so could this unit support 4 monitors? The AMD Ryzen 7 5800 in laptop configuration appears to support the device screen as well as 3 external monitors. If this is the case I would attempt dual monitors through USB C then one through each HDMI and Display Port.
Thoughts?
