- #1
Hi,
I would like to seek for assistance with connecting OneXGPU external GPU with the GTi14 Ultra via thunderbolt 4 USB -C adapter.
The onexGPU comes with it’s Power Supply Unit, and is already properly connected. According to the user manual it only works with USB-C TB4 connection with any miniPC/Laptop.
I have connected the OneXgpu to the TB4 adapter at the back of my beelink GTI14 Ultra 9. The E-GPU powers on and blue lights lit, however the fan doesn’t spin, the RGB lights doens’t turn on, and the E-GPU is not able to be recognized by the system.
I tried to use different USB-C cable, but it resulted with no difference. One of my cable is a wattage measuring one, and it shows there is a “PD” logo but no active wattage detected.
Is there anything i can do to make the E-GPU works? THanks!
