Does the GTI14 support both NVMe SSD’s to have a heatsink? I’m looking at the Samsung 990 pro with heatsink!
Thanks a lot!
    There is a heatsink and there’s a thermal pad attached to the base that sits in contact with the NVME drive. So Samsung 990 pro with heatsink doesn’t fit.
    1d1urem0m Hello! I use Samsung 990 pro 1Tb in Gti14 ultra 155H without heatsink and max temperature under load is 65 degrees Celsius.
    My review
