- #1
Hi,
Just wondering if the Beelink EQ13 MiniPC comes with an OS installed? And is it compatible with Windows 11?
Thank you
Hi,
Thank you
Madman00901 Our eq 13 machine comes with windows 11 pro system
wish you have a nice day
support11 Awesome, thank you. My EQ13 arrived this morning :)
Are you able to supply me with the Windows 11 Pro product key, please?
Madman00901 send to you by pm,please check
I need to reinstall Windows 11 Pro on my new EQ13.
Where could I find the Windows Cd-Key?
support1 I need to understand how to solve the issue occuring after the last windows update installation.
I have bought this computer, after windows 11 Pro update the system will freeze.
I have tried to repair and then to reinstall the full OS.
Each time I do the update through official Windows Updated and it install the KB5041585 and KB5042099 the system will be corrupted.
How to solve those issues ?
Hjogi Hi there,
Do you reinstall the system from Microsoft website ?
Here is the image https://mega.nz/file/XqYAhZJa#6YeSZExfkUmmuyQNmotv4bPq0Y0EcCyqK_aZ1cis4mo
Here is the picture tutorial https://mega.nz/file/KjZHyIqB#0EEVnG_1fWYCq_qL7GUYFGuD7nKqlV8FZWu78SVGXS4
Here is the Video tutorial https://mega.nz/file/rjw3DLjB#oCO056vM5R3bB2f1n9Kqj9aTF7eHDqGsmVghNekhsP4
I have downloaded the image and created the pendrive as per your guide. The issue this time is that once I boot into this new installation I got an error NVME disc not present.
