The ESXi 8 install fails due to lan drivers missing. Is there a driver package available for this?
    gman EQ13 driver send to you by pm,please check
    2 months later
    I’m having the same issue. Could you send it to me as well?
      uenouan EQ13 windows driver send to you by pm,please check
      Thanks for the driver files, but it’s for windows.
      Could you give me some instruction on how to apply it when installing ESXi 8?
        uenouan The EQ13 network card does not support ESxi8.0. You can try installing ESxi6.0 or 7.0.
        2 months later
        Hi, I am also in need of the driver for an ESXi install. Can you also refer me to a link for adding it to the EXSi ISO image. I am running into the same issue with no network driver found. Thank you
          WillAria Can you provide a picture of the SN code of the machine? We will send you the corresponding driver
