Tell me how to connect an external 3.5″ HDD to it?
There is an external box with external power and USB 3.0, but my SE7 does not see it. In Win 11, the device is defined as a USB to ata/atapi bridge and this is with a USB 3.0 cable.
If you take a 2.0 cable, then the system sees it perfectly, not with 3.0. The cables are serviceable, the external box is also checked on other computers.
Thank you in advance!
