Hi all. I have problems with all 3 front USB connections ( 2x USBA & 1x USB C)on my Mini Beelink Model SER 5th Gen. SN Y55604DH80553.
The connection to the USBs drives is continuously interrupted. I have exchanged the drive , but problem continues.
Maybe I need a Bios update. Can anybody check if there is a new version solving this problem?
Or maybe somebody experiencing the same can give me a trouble shouting?
Current version is from AMI version FP655U509 from 12.12.2023
Baseboard Version is V1.0
Prozessor AMD Ryzen 5 5560U with Radeon Graphics, 2301 MHz,
Thanks for your help
