I have mini pc Beelink SER5 Mini PC AMD Ryzen 5 5600H , win 11 pro, that I bought last year. I can not find touchscreen option in device manger under HID. Also when I search for “pen and touch” , it says “pen and touch not available for this display”. My current monitor doesn’t have touchscreen ability but I was planning to buy a touch screen monitor. So I am not sure if this mini pc, support touch screen at all!
Appreciate any suggestions!
Could you please send us a picture of SN on the bottom of the PC ?
the image was big to include
So It is:
SN: 5600H2CG00166
SER5 PRO-E-16512EJ0W64PRO-HA2
Thx!
    motor50
    The Type C port can support touch screen.
    Thank you…so why I can not find touchscreen in device manger under HID ( human interface) and how to manually add that driver?
      motor50 Hi there,
      You may need to update the driver from the touch screen monitor manufacturer
      Thank you
      I asked the same question from support team under “ contact us” and waiting for their response. I see some drivers under upload but I can not find the specific driver for SER5 that relates to touch screen. If you know the specific driver please let us know!
      Ok…I was to told by support team that this model doesn’t support touch screen monitor
