I recently got a SER 5 with the AMD 5560U processor. This this thing is great except for an audio issue I can’t seem to resolve. The audio is about a second behind everything. I’ve tried different browsers for YouTube, trying playing a video file, updated drivers, tried different speakers on the headphone output. Tried running through a TV via HDMI . . . the sound is always behind the video. Even in the Sound Setting screen, when I test the output, the little sound meter bounces about a second before the sound is heard. So, it doesn’t seem like a video sync issue necessarily. Any ideas?
HI there
Glad to help, Sorry for the trouble when using.
Please try some solutions here :
CLR CMOS
Secondly, Please hit the “CLR CMOS” button for about 10 seconds.
Please wait until 10 minutes later (THIS IS VERY IMPORTANT),
Then plug the power supply and HDMI cable back in, turn on the PC again,
Reset
Do this twice
Please try each option one at a time, then see if Windows will boot . . .
Then start the Reset
15 days later
There was a reply from Support4 here but I don’t know where it is now. Here is a copy . . .
HI there
CLR CMOS
Reset
Do this twice
Have you tried to clear the cmos and reset the PC?can it help you?
I have tried clearing the CMOS about 5 times. The delay improved from about .8 seconds to about .3 seconds (I used a YouTube video for measuring the delay). Its better but still very noticeable. I will try the System Repair method next when I have time. Thanks.
You are welcome. We are happy to help you.
If you have any questions , please feel free to contact us.
Have a nice day!
8 days later
Now I’ve tried the windows troubleshooting thing . . . which did not find a problem. I uninstalled the AMD software I had added (thinking it would have all the best drivers). I have reinstalled Windows. Nothing has helped, so far.
I also just now tried the Recovery environment. Startup repair did not find anything. I didn’t bother with a restore point since its a fairly new box and the sync was never correct. The only thing I haven’t done is reset the PC. I am skeptical that this will do anything . . . as mentioned, its a new box. I could do that . . . I don’t really have any files that are local only but I’d rather not have to reinstall all my apps (reset options do not seem it include keeping apps . . . just keeping files).
Here is the driver file: https://url.bee-link.cn/SzSO
The tutorial: https://url.bee-link.cn/wEmk
It is recommended that you try to update the graphics driver, audio driver, and chipset driver.
The method of updating is to delete the original driver in the device Manager first, and then install the driver file we provided.
Have a nice day!
Post 7 and 8 of this thread is not visible for some reason. In any case, the driver file you link appears to be just the AMD adrenaline software, not a library of drivers. I did follow the instructions you gave. however, when I removed a device from the Device Manager, Windows seemed to automatically re-install it. When I tried to update the driver and opt to look in the unzipped version of the directory you linked, Windows just said the best driver was already loaded. Am I supposed to install the Adrenaline software? I had already tried that but it did not solve the issue. It could be that I didn’t do it correctly.
One thing that is odd is that there is an Other Devices section with one device, ‘Audio Controller’ that doesn’t have a driver and Windows cant find one.
Could you show us the driver that displays the audio controller in your device manager? Then we can help you better.
Would you like to try to reinstall the system to solve the problem? You can back up your data before reinstalling the system.
This is the system file: https://url.bee-link.cn/a3VR
Here’s the tutorial: https://url.bee-link.cn/s88O
Have a nice day!
8 days later
I tried using an external sound card (USB dongle) . . . same issue. Seems like the latency can be .3 seconds or .8 seconds. Here are my current audio drivers . . .
Image description
Image description
Image description
Image description
Image description
Hello Aaron,
Could you please take a picture of the BIOS main screen of your machine for us to see?
Here is the tutorial of how to check the BIOS version: https://mega.nz/#F!yuISGa4I!s1bQQajKwnsEdzjqq4nopQ .
Maybe updating BIOS can solve the problem.
Have you tried to reinstall the system?
We have previously provided you with the appropriate system files and tutorial.
We will wait for your reply!
Have a nice day!
I have not yet tried reinstalling from scratch. I am avoiding that because I’d rather not have to reinstall all my apps. I don’t save anything locally, so that’s not an issue. Bios version is FP655U509 . . .
Image description
Your BIOS is the lastest.
You can make a backup of all your software data before attempting to reinstall the system. That way you don’t lose data.
It is recommended that you try to reinstall the system.
Have a nice day!
4 months later
Updating this . . . I was resolved to reinstall Windows and started the 9.9 Gb download . . . this is not my main rig so I had just been avoiding using the BeeLink to play videos, but it still bugged me and I wanted to fix it . . . decided to check the sync one more time. It is perfect! I am without words . . . I did change my output device (from a Amazon Tap using aux in to a set of Bose companion speakers) . . . but, I switched back temporarily to see, somehow, if the Tap was delaying the audio for some reason. But, timing was perfect on the Tap as well. I have no idea what happened to resolve this . . . unless there was an update that fixed this or triggered some kind of re-calibration. I am 1000% the timing was off (based on observation and running sync-check videos). Hopefully this is fixed permanently.
    Thanks for responding, @support6 Wendy, but, in case I wasn’t clear, its fixed. I have no idea how. It must have been fixed in a Windows update somehow. I had tried everything but reinstalling the system and nothing had worked.
    OK, May i ask is your machine working normally now? Have a nice day!
