If you uninstall the graphic driver ,and you still encounter the timeout issue, please disable the windows update. To disable the Windows Update service in Services Manager, please follow the steps below: Press Windows key+R.Type services.msc,then hit Enter.Search for Windows Update. Right-click on Windows Update, then select Properties. Under General tab, set the Startup type to Disabled. Click Stop.Click Apply, and then click OK.
Then click Recovery tab–First failure choose take no actions, second failure choose take no actions, subsequent failures choose take no actions.
Have a nice day!
