Hello Fai9aL,
The links that you have given : https://url.bee-link.cn/pxhB : do not work please.
I tried everything but it seems there is some configuration in the BIOS which needs to be enabled.
Can you help with the exact menu in the BIOS which needs to be configured please?
I also did all of the below
Enable all below :
- “Allow the computer to turn off this device to save power” (This might seem counterintuitive, but it’s often necessary for WOL to function correctly).
- “Allow this device to wake the computer.”
- “Only allow a magic packet to wake the computer.”
In the Network “Advanced” Tab
“Wake on Magic Packet”: Enable
“Wake on Pattern Match”: Enable
“ARP Offload for WoWLAN”: Enable
“NS Offload for WoWLAN”: Enable
“Energy Efficient Ethernet”: Disable
“Speed & Duplex”: Ensure this is set to “Auto Negotiation.”
One interesting thing, ideally if the Wake up on LAN is enabled, it should keep the Ethernet port lights blinking even when you have shutdown the PC, right ? In my case all lights are switched off once I shutdown the PC.
Can you help please ?
Thank you
Manish Naik
