Hey, I’ve just bought SER9 with AI HX 370 and tried my eGPU Razer Core X Chroma + GeForce 3080, everything seemed fine except with eGPU connected it BSODs after 10-15 minutes of eGPU being used(started a game or video decoding).
Windows Event Viewer recorded STOP-error 0×00000124 (0×0000000000000004, 0xffffe50a0412e028, 0×0000000000000000, 0×0000000000000000).
I’ve updated Windows 11 to the latest versions and allowed windows autoupdate to update drivers to the latest version but nothing seem to help. Checked your downloads page for any downloads or bios updates but it doesn’t even list this model yet. At first I thought it might be an overheating issue so installed HWiNFO 64 to check temps while running game but they look ok, also I’ve tried to run same tasks with no eGPU(on internal GPU) and could normally use the device, no issues at all.
Is this a known error? Is it planned to be fixed or is it a hardware issue and I should request a replacement?
If you need more info on this or dump files(they are 3-4 Mb each), please let me know.
Edit 1: My current BIOS version SER9.V103.P8C0M0C15.55 and I’ve found out that you post bios updates in News/Blog section, would be great to be able to find them also in Downloads section. My device SN starts with Y and it seems there are a BIOS update for my cause in January BIOS update(https://www.bee-link.com/blogs/all/bios-update). The version I need is “V103.P8C0M0C15.68” which says “Resolved blue screen issue when connecting the dock and eGPU, optimized Linux system compatibility”. I’ll give it a try once I get an empty flash drive.
Edit 2: I’ve done everything by instruction(it didn’t require any command inputs and completed everything automatically), I was able to flash my BIOS with forementioned update and it looks like everything works fine now. I’ve tried same tasks as I performed before and having no BSODs, so it actually fixed the issue. With this setup I can run DOOM(2016) on 1440p with Ultra settings and getting 175-200 FPS.
Dragons Dogma 2 FullHD Priortitize Graphics preset 42-50-60 FPS
Spacemarine 2 1440p High/Ultra 38-45-61 FPS
Stalker 2 FullHD Normal 28-34-51 FPS
