MasterGio Hi everyone, i bought my SER9 a week ago, and it’s all fine but I need to konw why my bios does not contain the “OEM feature management”. i want to switch in performance mode, but not find that label on bios! any help?
Beelink CS-Rose https://buildin.ai/lizong/share/97f0964b-3494-4859-88a9-69a3854b4cd5 here is a tutorial for your reference, pls check if this helps firstly, thanks
MasterGio this is the image of my bios advanged page. it’s visible? I don’t know if it’s relevant or not, but on my PC the BIOS version is SER9T103
MasterGio Yes, I tried the combo ctrl+F1, but no option unlocks in the BIOS. another possible solution? thx
Beelink CS-Rose Please repeatedly press delete key as soon as you turn on the PC, go to BIOS-Advanced—AMD CBS–SMU Common options—System configuration—you can set 54W or 65W–press F4 to save and exit. pls try this tutorial, thanks
Beelink CS-Ian Chan AlexSea Please email us with SN pic and BIOS version . So we would be able to know whether it is latest BIOS and send you files accordingly. Here`s how to check your BIOS version: https://mega.nz/#F!yuISGa4I!s1bQQajKwnsEdzjqq4nopQ
