- #1
Can anyone point me to the latest BIOS for the SER5 Max? I’m currently on 602.
Thanks
Thanks
The latest version for SER5 MAX 5800 is 605.
Please send us a picture of SN for confirmation.
Then we will send you the BIOS and tutorial.
support1
My unit is currently installed under my desk bottom side up and I can’t easily remove it to capture the serial number. I have this from the box:
Thanks,
beelink123 Please check your private message
