JY
Please send us a picture of SN on the bottom of the PC .
Next,please take out one RAM and leave the other one in it to test if the RAM is defective or not. When testing, please turn on the PC, and wait about one minute, if you can go to the system, Please repeatedly press delete key as soon as your restart the PC, go to BIOS. Go to Boot option, enable fast boot, press F4 to save.
②Please update the BIOS.
I have sent you the lastest BIOS file, please check your PM.
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one.
Here is the driver file: https://url.bee-link.cn/bcEf
The tutorial: https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Have a nice day~
