①Please try resetting your computer
Do this twice
Then start the Reset
②Please try to re-install the system.
Pls backup your data firstly, re-installing the system will make your data in your pc lost.
System: https://url.bee-link.cn/glzL
Tutorial: https://url.bee-link.cn/s88O
