Neither usb or usbc will not load my portable ssd. Was working fine. Works on phone and laptop. Phone will not now connect either. States not enough power. My powered external hard drive connects ok.
Thanks for some help
Ser7 amd 4700u
    Bgee
    1. Please clean the USB port with 75% alcohol
    2. Please uncheck the save energy in the device manager—universal serial bus controller–USB hub—properties–power management—uncheck “Allow the computer to turn off the device to save power”
    3. Please turn off the PC , unplug the power supply and other USB devices, then put the pin in the CMOS pinhole and press it for about 10 seconds , restart the PC after ten minutes.
      Here is the tutorial https://url.bee-link.cn/5FdW
    I have followed all your instructions and still have the problem. I’ve tried all 4 usb ports and the one usbc. I have also tried different cables.
    Bert
    Please send us a picture of the SN on the bottom of the PC.
    1. Update or Reinstall Driver Programs
      Update Drivers: Open “Device Manager”, expand “Universal Serial Bus controllers”, right-click on the corresponding USB controller and choose “Update Driver”. Follow the prompts to search for and install the latest driver programs.
      Reinstall Drivers: In “Device Manager”, right-click on the relevant USB device and choose “Uninstall Device”. Then restart your computer, and the system will automatically reinstall the drivers.
      2.Troubleshoot System and Other Settings
      Run the Troubleshooter: Search for and open “Troubleshoot” in “Settings”, select “Hardware and Devices”, and then run the USB troubleshooter. Follow the instructions to let the system find and fix the problem.
      Check System Files and Registry: Open Command Prompt as an administrator, type the command “sfc /scannow” and press Enter. Wait for the system to check and repair damaged system files. Open the Registry Editor (press Win + R, type “regedit” and press Enter), navigate to “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR”, and make sure the “Start” value is set to 3. If it’s not, change it to 3.
    Thanks for your detailed response.
    I worked my way through all the steps including “scannow” which showed no issues. I navigated my way to the “USBSTOR” page but was unsure how to check for or change the setting to 3.
    I have attached 2 photos.
    1. The serial number. (You requested)
    2. A copy of the USBSTOR page
      Could you advise on how to check or change?
      Image description
      Image description
      Bgee Hi there,
      The value is already 3.
      Does other USB flash drive work on these ports ?
      I’ve summarised what’s happening.
      Stopped recognising samsung ssd using usbc to usbc or usb to usbc. (Still works fine on laptop)
      Tried several cables.
      Samsung s21 ultra will not now connect properly. (As above works on laptop and have tried various cables)
      Reads a flash usb
      Reads a SSD and 31/2 drive in caddy using usba? Connector. (Although my bluetooth dongle used for mouse and keyboard does not work when drive plugged in)
      Have checked and run all tests you asked
      Question
      Could the usb and usbc suddenly not now be getting enough power?
      I assume if I by a powered usb hub that may solve the problem of not being able to read the Samsung ssd!
      Still doesn’t solve the issue with the usb and usbc ports
      Thanks very much for your patience
      Bert
      Hi Bert,
      Did you change /update the operating system recently ?
      • #9
      Nothing was changed. ..
        10 days later
        Bgee
        Please reset the PC.
        Do this twice
        Then start the Reset
        20 days later
        • #11
        Sorry for the delay in responding. I have been away from home.
        I worked my way through your suggestions but unfortunately I still have the same issue.
        Bert
        5 days later
        Please go to AMD website and download the auto-detect program.It will update some chipsets and video drivers automatically. It will identify and install appropriate drivers for their AMD hardware. The program works by scanning the user’s system to detect the installed AMD hardware components, such as graphics cards or processors. It then compares the detected hardware information with a database of AMD drivers and software versions.
        If the problem persits, you can consider sending back for replacement
        11 days later
        • #13
        Did as advised with AMD auto detect. Unfortunately still having the same problem.
        Bert
          8 days later
          Bgee Hi there,
          You might need to think about reinstalling the system.
          Here is the tutorial https://url.bee-link.cn/74zu.
          Please back up the data before the installation.
