Hello from New York City!
Does the EQR6 mini PC on Amazon have space for an extra hard disk drive for Linux?
Does the BIOS offer dual boot?
How easy is it to open box to install second SSD and configure?
Any clues appreciated. Thank you.
EQR6 has two SSD slot which means you could add an extra hard disk drive for Linux if you want Image description
And it can support dual boot.
You could refer to this tutorial: https://url.bee-link.cn/D2zz
a month later
Well thats a good news im tell u.
i just bought a erq6-d5 ryzen 7 7735hs 1 tb with win 11 os, i intend to dualboot with “Steam Os” or “Bazzite” so my daughter’s can play without problems. Basicly turning it into a “$team machine”. I will put a steam sticker on it “No offence”, just want it to be cooler.
i wont receive it untill the end of February ( 25th ish ). I ordered the stuff needed (extra ssd 1tb, screen, controller, Wireless kb/mouse combo “Pink” the whole shabang )
So question, wich one would run better: SteamOs or Bazzite.
and
do the ram size effect the internal gpu ?
is it possible for an external gpu ? ( if the gpu is too weak ) oculing or something….
any overclocking possible ? ( gpu mostly )
Thank you
    Stereo SteamOS is a Linux-based operating system developed by Valve Corporation specifically for gaming. It comes with the Steam client pre-installed, allowing you to easily access your game library and play games. SteamOS is optimized for gaming performance and has a user-friendly interface designed for use on a TV or monitor.
    Bazzite, on the other hand, is a cloud-based operating system that provides a fast, secure, and reliable computing experience. It uses virtualization technology to allow you to access your operating system and applications from any device. Bazzite is not specifically designed for gaming, but it can still be used to play games through cloud gaming services like Google Stadia or GeForce Now.
    In terms of which one would run better for gaming, SteamOS is likely the better choice as it is specifically designed for gaming and optimized for performance. However, Bazzite may be a better choice if you need a more versatile operating system that can be accessed from any device.
    Ultimately, the choice between SteamOS and Bazzite depends on your specific needs and preferences. You may want to try both and see which one works best for you and your daughter’s gaming needs.
