CliffW Beelink GTi14 Mini PC Intel Ultra 9 185H, Intel Arc Graphics GPU is there somewhere in setting or bios that allows you to select dedicated memory for the graphics? I found in system information that the GPU is only using 128mb. The Gpu does no seem to be strong enough for some video to play well.
Beelink CS-George Hi there, Sorry, for intel PC, the VRAM is usually fixed, about 3 or 4GB by default. Could you pelase go to BIOS and send us a pciture of the VRAM value you have ?
CliffW I have been in the bios and see no VRAM. I looked in all areas of the bios and do no see it anywhere.
Beelink CS-George CliffW Hi there, After I check ,there is no VRAM option in the BIOS. Are you using EGPU?
