I. realize that currently it does not, as the specs say it is version 5.2, however, it is on a replaceable card that can be upgraded and so I was wondering if you will be supplying and upgrade option, either the Bluetooth card or a firmware update.
By the way, I am currently booting off either slot one or two, by choosing the f7 option, but by current default boot disks is slot two. and the original slot one windows NVMe card still resides in slot One.
Regards, Steve43
