TonyE Enjoying my Ser-6 but there are two (2) devices in the Device Manager that can’t find drivers: AMDI - 0052 (Unknown) 1022 - 15E2 (Multi-Media controller) Where can we obtain the drivers? Thanks Tony
Beelink CS-Rose These are external device drivers, if the machine is working properly just ignore them. They will be installed automatically when you connect different devices.
TonyE I Don’t think that is accurate. If I “Uninstall” the devices, and then “Scan for hardware changes”, they pop right back up. That means that they are attached directly to the computer… (?) Tony
Beelink CS-Bettie TonyE Hello, You can first follow this tutorial to install the driver:https://url.bee-link.cn/wEmk Best regards! Wendy Customer Support
