Just got a new S-13. Unfortunately, when I turn it on, nothing shows up on the display. The power light comes on, and there is a bit of hot air coming from the vents, but otherwise nothing.
I am using an HDMI to DVI cable to connect to the display. Is there any way to tell if it’s a problem with the PC, or a bad cable? I don’t have access to an actual HDMI display.
